×I want to be able to add an Organization to an issue after creation even if the reporter chose not to share it with anyone. I currently have this working via automation, but we have so many tickets, it's maxing out our allowed automation runs, and we don't currently have another reason to use premium.
I can find older scripts to populate the Organization field based on the reporter, but I can't find any that work with the current version of Jira Cloud.
Does anyone have a sample script to do this?
Hi Destri,
The example library script here shows how to add users to an organisation when an issue is created, and this may be a useful reference guide to help you to create the script that you require.
I hope this helps.
Kristian
Thank you! I already have the users in organizations, but I want to add the organization associated with the user to the ticket automatically.
Hi Destri,
I this case you will need to add a script to call the edit issue API and to set the body for the organisations field.
The best way to see what structure the organisations field uses is to run the example script on the script console called Get Issue Fields to return an issue which has this field set.
This will show what structure it uses to help create the correct body structure to set this field.
If you still need further assistance with this script, can I please ask you to raise this issue as a support ticket here so that our support team can help investigate this and help you with writing the script.
I hope this helps.
Kristian
I entered an issue with Adaptavist (Help writing script - ScriptRunner for Jira Cloud - Service project (adaptavist.com) and attempted to write a script using the help they provided, but I'm currently getting a startup failed error (and others, too).
Any idea what I'm doing wrong?
// Step 1: Get the current issue's reporter's accountID
def issueKey = issue.key
def result = get("/rest/api/2/issue/${issueKey}")
.header("Content-Type", "application/json")
.asObject(Map)
.body
def reporterAccountId = result?.fields?.reporter?.accountId
if (reporterAccountId) {
// Step 2: Get all existing organizations
result = get("/rest/servicedeskapi/organization")
.asObject(Map)
.body
def organizations = result?.values
// Step 3: Find the organization of the reporter
def reporterOrganizationId = null
organizations?.each { organization ->
result = get("/rest/servicedeskapi/organization/${organization.id}/user")
.asObject(Map)
.body
def members = result?.values
if (members?.any { it?.accountId == reporterAccountId }) {
reporterOrganizationId = organization.id
return
if (reporterOrganizationId) {
// Step 4: Update the issue's organization field
result = put("/rest/api/2/issue/${issueKey}")
.body([
fields: [
organization: [
.asString()
Errors are:
2024-03-01 20:40:20.983 ERROR - startup failed: Script1.groovy: 47: Unexpected input: '{\r\n // Step 2: Get all existing organizations\r\n result = get("/rest/servicedeskapi/organization")\r\n .header("Content-Type", "application/json")\r\n .asObject(Map)\r\n .body\r\n\r\n def organizations = result?.values\r\n\r\n // Step 3: Find the organization of the reporter\r\n def reporterOrganizationId = null\r\n organizations?.each { organization ->\r\n result = get("/rest/servicedeskapi/organization/${organization.id}/user")\r\n .header("Content-Type", "application/json")\r\n .asObject(Map)\r\n .body\r\n\r\n def members = result?.values\r\n\r\n if (members?.any { it?.accountId == reporterAccountId }) {\r\n reporterOrganizationId = organization.id\r\n return\r\n }\r\n }\r\n\r\n if (reporterOrganizationId) {\r\n // Step 4: Update the issue's organization field\r\n result = put("/rest/api/2/issue/${issueKey}")\r\n .header("Content-Type", "application/json")\r\n .body([\r\n fields: [\r\n organization: [\r\n id: reporterOrganizationId\r\n ]\r\n ]\r\n ])\r\n .asString()\r\n }' @ line 47, column 22. } ^ 1 error 2024-03-01 20:40:20.983 ERROR - Class: com.adaptavist.sr.cloud.workflow.RunScript, Config: [className:com.adaptavist.sr.cloud.workflow.RunScript, uuid:de5a0a77-789c-4a5d-92bb-6928da7ab7f8, enabled:true, executionUser:INITIATING_USER, condition:// Step 1: Get the current issue's reporter's accountID
It looks like you may be missing a closing } at the end of your script.
Thank you so much for your help so far. I think I'm close, but I just can't get it to work.
The following script runs without error, but the GET /rest/servicedeskapi/organization/851/user asObject does not evaluate to true. Any idea what I'm doing wrong here?
.asObject(Map)
if (result.status == 200) {
def reporterAccountId = result.body.fields.reporter.accountId
.asObject(Map)
def organizations = result.body.values
organizations.each { organization ->
.asObject(Map)
def members = result.body.values
if (members.any { it.accountId == reporterAccountId }) {
return
.body([
fields: [
"Organization": [
.asString()
if (result.status == 204) {
log.info("Organization field updated for issue: ${issueKey}")
} else {
log.warn("Failed to update the organization field. Response: ${result.status} - ${result.body}")
} else {
log.warn("Reporter not found in any organization.")
} else {
log.warn("Failed to retrieve organizations. Status: ${result.status}, Response: ${result.body}")
} else {
log.warn("Failed to find issue: Status: ${result.status} ${result.body}")
Hi Destri,
Does the organisation have any users, as I have tested the rest call and it is the correct syntax.
To get help with debugging this script further, I would advise you to raise a support ticket here for our support team to help debug this further.
Kristian
I am a user in the organization. I have this script running as a post function on the Create transition, I expect it to add the organization to a new request when I create one.
Hi Destri,
Please can you raise a support ticket for this, as requested, so that our support team can diagnose the issue further for yourself?
Kristian
