Hi @Heyjin Hope you are doing well!
As per the screenshot, it seems that Component field is empty of the issues or you have multiple Component field in your instance. Try to search for Component/s or Components column and add that field.
System component field name is Components not Component.
Thanks for your help! I have another question, though. I added "Issue Type" to the columns, but this category doesn't show up at all. Why might that be? Could you explain this ?
@Heyjin Glad to hear your component issue get fixed.
Issue Type shows icon only, not show name of the issue type. You can hover over icon to see issue type name.
