Search by linked issue
Martin Vali
Hi, Would like to search issues in project A that has linked issues form project B.
Chat GPT gave following
issue in linkedIssuesOf("project = ABC")
but that does not work
3 votes
Evgenii
Hi, @Martin Vali
ChatGPT is slightly wrong. For Jira Cloud JQL query looks like:
issue IN linkedIssues("NTL-2")
Evgenii
Like • 2 people like this
Martin Vali
Wow - works like charm, thanks for fast answer. I already love Jira community
Kristian Walker _Adaptavist_
Hi Martin,
linkedIssuesOf is a JQL function provided by the ScriptRunner for Jira Cloud or Enhanced Search for Jira Cloud apps.
To use this you would need to install these apps and use the Enhanced Search page it provides.
I hope this helps.
Kristian
said kouzibry
September 25, 2024
This is not something you can accurately achieve with standard JQL.
The closest solution I could find was linkedIssue IN projectsLeadByUser(accountId) where accountId is the id of the project lead of project ABC, this assumes project ABC can be identified using the project lead only. Meaning that user should only be project lean in that project.
Otherwise, I don't see how it can be done. What is your ultimate goal behind this ? Do you want to perform some action on these issues ?
Manoj Gangwar
Hi @Martin Vali  Welcome to the community!
If you have script runner plugin installed then you can use the above function.
For that, you need to click on the apps option at the top and then click on the ScriptRunner Enhanced Search option.
Then JQL should be Project = project1 AND issueFunction in linkedIssuesOf("project = ABC")
