Searching for a Test Case Managment that is able to create bugs as sub-task! Any idea?
Manuel Moya March 26, 2013
I'm searching for a TCM Tool than can be integrated into Jira / Greenhopper. The tool should be able to create bugs as a sub-task for a Requierment.
I've looked into Zephyr & SynapseRT but both tools are only able to create bugs as Issues, not as sub-task for an issue.
In this cases the bug i not visible on the scrum board and also is not "good" assigned to the related Requierment. I need a bug that is instantly visible on the board (and in this way also trackable by the burn down)
Does anybody knows a test case management that is able to create bugs in the wanted way?
Or maybe it's just a config issue in Zephir / SynapseRT (or the board) that i did'nt found or maybe i misunderstand the usage of this tools?
Manuel
codelab expert
April 2, 2013
No, there is no way. A subtask is a mechanism to split big problems into small problems. So it is no good idea to put bugs under a test case - you must link them. The bugs are shown in the backlog, so your project management can assign them to the desired sprint.
Manuel Moya April 2, 2013
I don't want to put bugs under a test case. I want to put bugs, out from a test case under a Requierment. And sure, the test case and the bug should be linked.
Also in this way there is no manually assignment neccessary.
Chris Miller
April 1, 2013
Hi Manual,
Here at Zephyr we'll add this to a feature request list. It isn't currenlty possible.
Kind Regards,
Chris
