Selection of fields based on an option
Francisco Navarro
Dear community,
I am creating a type of requirement that will be entered through the JSM self-service portal. I have the challenge of creating a series of fields to be completed, but these must be activated or appear based on a specific selection of a combobox with the options.
I thought about creating forms with the fields by option and that they are loaded when something is selected in the combo, but I don't know how to do it.
Do you have any step-by-step instructions on how to create something like this? A use case example would be very helpful to me in understanding how to create something like this.
Victor Law
Hi @Francisco Navarro
You may refer to the following short video from Atlassian for the guide on how to create a dynamic form:
https://www.youtube.com/watch?v=gyHCj84_ZwQ
Thank you.
Francisco Navarro
Thank you very much for your help! I will review the video to see if this helps me with what I need.
Learn more
