Send slack message if user doesn't have in progress issues
Petar Cvetanovic
I want to create automation for 33 employees that i am managing.
The automation should following:
1. Filter all task per specific assignee
2. Check if filtered issues statuses and if the assignee doesn't have issues in "in progress" status, send a Slack message reminder.
The biggest problem that i don't know how to handle is how do do the second part
Important - check video explanation -
https://www.loom.com/share/95178fb0b3424663a88110d8c08be406
February 20, 2025 edited
Hi @Petar Cvetanovic
With the changes to Slack REST API, it is no longer possible for a Jira Automation rule to send a direct message to a specific Slack user using the Atlassian-provided Slack connector.  (Although the Atlassian documentation and UX have not updated to note that yet.)
Instead, one may send to a specific channel and mention the particular user if you have their Slack ID.
If you have a different connector for Jira to Slack, please investigate that app's documentation to learn if there is a REST API endpoint for sending direct messages.
Petar Cvetanovic
Sending Slack messages is not a problem. We can do it in the channels. The problem is how to
Filter all tasks per specific assignee, check filtered issues statuses, and if the assignee doesn't have issues in "in progress" status, do some action (send in slack message in channel)
February 21, 2025
Without seeing the specifics of your automation rule, I am guessing it uses the Lookup Issues action to find the issues and send the list.
In that case, either the JQL could be adjusted or the smart value, list filtering could be used:
https://community.atlassian.com/t5/Automation-articles/Filtering-smart-value-lists/ba-p/1827588
Petar Cvetanovic
Hey, grateful for helping me. Here is the logic that i am using and for some reason, it's sending both messages.
1. I filter all issues assigned to a specific assigned.
2. If specific assignee has issues in progress i send the message - "Nothing user has "In Progress" issues
ELSE send reminder message
Where i am wrong?
Video explanation -
Part 1 - https://www.loom.com/share/b0b23def404d4b9faf60f33687c34c04?focus_title=1&muted=1&from_recorder=1
Part 2 - https://www.loom.com/share/f9e8bc2005774e29904b480ae8a2dd89
February 25, 2025
As written, that rule will send a Slack message for every issue which has the Assignee noted in the first condition.  And because of the first condition, it will also never send the "nothing in progress" message.  Is that what you wanted?
Also, this rule will only work for that assignee, and no others.
I recommend pausing to clarify what problem you are trying to solve.  That is, "why do this?"  And then explain that problem to your Jira Site Admin to ask their opinion on how to solve it.
