I have an interesting issue here:
I am trying to send a JSON payload to DataDog to start an Incident (using their On-Call feature).
I send the following payload and it works:
"title": "Something Silly Here",
"text": "Maybe some Description Text",
"tags": "team:{{customFields.customfield_15951.asJsonString}}, incident", "source_type_name": "Jira",
"alert_type": "info"
However, when I attempt to use additional Smart Values like the below example, I am get an error:
"title": "{{issue.summary.asJsonString}}",
"text": "{{issue.description.asJsonString}}",
Error:
Through some trial and error, we were able to get the formatting right for both sides. Tested via https://webhook.site/:
What worked is below:
asJsonString wraps the string in quotes. When it's expanded, you're sending:
"title": ""summary"",
"text": ""description"",
"tags": "team:"customfield", insident",
...which I don't think is what you want. I would remove the quotes wrapping the title and text values and try again.
Thanks! We discovered this as well. We did find a solution!! (posted separately)
