Sending multiple Components into JIRA using Rest API
Arun Unnikrishnan
August 26, 2024
We're using a MS form to collect Ideas, and these ideas or the form responses will be created as an issue in a jira project.
We're using Power automate to achieve this. We're able to successfully create JIRA issues and populate the Component field in Jira from the form response. However, when the user selects multiple responses in the form, which is mapped to the components in jira, the components are sent as a single object which is comma separated.
The components are already available in jira.
Few screen shots for your reference
The JSON which is sent to jira with value
This is how it is shown in JIRA
In jira it is treated as a single component. I want this to be three separate components which are already available in JIRA.
Thanks in advance!
Alex Medved _ConfiForms_
Hi @Arun Unnikrishnan
Components in Jira REST API are set like this
"components": [
{ "name": "TSM" },
{ "name": "SA" },
{ "name": "SYE" }
Hope it helps
Alex
John Funk
August 26, 2024 edited
Hi Arun,
Try this:
      "update": {
               "components":[{"add":{"name":"TSM"}},{"add":{"name":"SA"}},{"add":{"name":"SYE"}}]
Arun Unnikrishnan
August 26, 2024
@John Funk | @Trudy Claspill Any suggestions? TIA
Register here ⬇️
