I have a single project with two different boards for different teams. Issues constantly get confused - an issue for team A opened in board A may appear in a board for team B.
Is there a way to keep backlogs and sprints independent?
Hello Lilit,
in Board settings you should be able to specify filter which defines which issues to show. Therefore you can have one backlog+board for Team A (e.g. filtered by component, custom field or whatever you use to divide issues) and another one for Team B.
Kind Regards,
Martin
Hello Martin,
Thank you for your response. The problem is there is not separate settings for a Board, I can manage Project settings.
The second issue is that although I have 2 boards and 2 components - one component per board - and I create issue saying for board A with board A's component, the issue appears in Board B as well
1. Create separate filters to define each board
2. Create each board using the saved separate filter
