Hi Community,
Pre-requisites:
Requirement:
I referred to this scriptrunner behavior example:
https://www.scriptrunnerhq.com/help/example-scripts/Make-field-read-only-based-on-user-groups-cloud
But I'm not getting any success as user from specific group is still able to edit the field on Cancelled. Fields should be editable only on other statuses instead of Cancelled.
Please guide on how to set fields ReadOnly on Cancelled by tracking the Transition ID and user group.
Please provide a sample code using scriptrunner / any Post-Function which can be used for ReadOnly or any JMWE app to achieve the above as it will be a great help.
Thanks in advance.
Hello @Digvijay Singh Gehlot
Please provide a copy of the script that you have created that is not providing the expected results.
Can you clarify the intent of your requirements?
