Set a default layout in projectrak for new projects
Laura Jimenez Valencia July 26, 2023
Is there a way to make all projects (and when creating a new one) default to a created layout instead of the default one in projectrak? that is, not having to be changing the layout but rather everyone already having the new layout by default.
Fede Baronti -Deiser-
Hi @Laura Jimenez Valencia ,
I'm Fede Baronti from Deiers, Projectrak's developers. Thanks for writing your question about Projectrak.
I believe you have also opened a support request with this same question, and my colleague Carlos has already answered this question.
But in order to share knowledge about Projectrak: unfortunately, Projectrak does not have the ability to associate Layouts with projects by default.
On the other hand, we have a workaround for this situation: with the help of Jira Automation, you will be able to Automatically set a Default Layout for your projects. You can find the full explanation and configuration right here: How to automatically set a Default Layout for my Projects. It should be an easy configuration.
Hope this helps and please, if you have any further questions, do not hesitate to let me know.
Thanks and all the best.
Laura Jimenez Valencia August 16, 2023
Thanks for the answer!
