Set custom date on field on a post-function transition
Matheus Tonial
November 26, 2024
I made a post function to set a field date to today, but I needed to add 7 days to it, I try many different ways but none work, any suggestion on how to do it on the post function and not with automation?
I didn't find any post that would solve my problem without using the script runner
4 votes
Marc - Devoteam
November 26, 2024
Hi @Matheus Tonial
Welcome to the community.
This is not an option, you will need a marketplace app, like;
  • JMWE
  • JWT
  • JSU
  • Scriptrunnner
These apps can enhance workflow options and help you with your request or use Automation for this.
Shiva Kumar Hiremath
November 26, 2024
Hello Matheus Tonial,
you can use the below mentioned screenshot Automation rule to edit custom date field.
Kai Becker
@Matheus Tonial welcome to the community and thank you for your question.
I would recommend using an Automation Rule to set the date with the appropriate timestamp. This does not require an app at all.
Documentation on working with dates in Smart Values: https://support.atlassian.com/cloud-automation/docs/examples-of-using-smart-values-with-dates/#Calculating-business-days
November 26, 2024
you can use the below mentioned screenshot Automation rule to edit custom date field.automation to add days.PNG
Dick
Hi all,
A very similar question has been asked previously in this community:
How can I set a custom field date one week *before...
I'm hesitant to say that Google is my friend, but here it helped...
Dick
Marc - Devoteam
November 26, 2024
Hi @Dick
You mentioned article relates to Trello and not JIra.
Dick
November 26, 2024 edited
Hi @Marc - Devoteam,
It's the line of thought in the article and the use of smart values (kindly mentioned by @Kai Becker as well) that are very similar to the problem described here.
There's more than one road leading to Rome
Dick
Marc - Devoteam
Hi @Dick
Yes in a way, but it can confuse people as all information in the article and related screenshots with configuration don't exist in Jira.
Hence this cold cause new questions from a user on options that don't exist in JIra
Nacho Moreno Ortega
I am Nacho and i am part of the Decadis team.
As @Marc - Devoteam mentioned, it can be done with our app Jira Workflow Toolbox for Jira Cloud.
For this purpose, the Update fields post function can be created combined with the parser function addDays() to add 7 days.
Here is the expression that can be used:
%{addDays({system.currentDateTime}, 7, RUN_AS_LOCAL)}
And two screenshot of the post function configuration:
If you need more information, please feel free to create a ticket on our support portal.
Best regards,
Nacho
FREE
