×Hi,
It's April 2024 and I see that everything is very time sensitive in Jira so post fresh question. Also tried few solutions from prev posts none of them worked for me.
How I can default my custom field (date type, date picker) 2 weeks from another Field with ID =1234 (custom or built in) . Is this possible? As an option it also could be from today().
For now I think it works only for text field.
Thanks much
Dima
Hello @Dima Astahov
You can use an Automation rule to update the field automatically after the creation of the issue is completed.
If you want to update the field to set a default value within the Create Issue dialog, where the value may be dynamic/relative to another field or the current date, that would require use of a third party app such as Adaptavist's Behaviours app.
https://docs.adaptavist.com/sr4jc/latest/features/behaviours
Thanks Trudy !! It this native Jira feature or this is app?
Automation Rules are native.
https://support.atlassian.com/cloud-automation/docs/jira-cloud-automation/
However there are limitations on how many rule executions you can have per month based on your subscription plan. Refer to
https://support.atlassian.com/cloud-automation/docs/how-is-my-usage-calculated/
Thanks Trudy, I did a rule, could not yet the way to manipulate (add 2 weeks) to my source field. But I will try to learn it.
Best
Dima
You'll need to look at smart values and functions for manipulating date and time data.
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-date-and-time/
If questions come up, don't hesitate to ask the community.
