Set default value in Custom field on Create transition using Scriptrunner in JIRA Cloud
Digvijay Singh Gehlot
Hi Community,
I am creating a behavior in Jira Cloud using scriptrunner, where I want to set a default value in Summary and Description fields on Create transition.
Please find the below code:
const summaryField = getFieldById("summary")
summaryField.setValue("Short Description of Release")
const descriptionField = getFieldById("description")
descriptionField.setValue("Long Description of Release")
Please guide if the above code is correct and will it work on Create transition, and let me know if it needs any refinements.
5 votes
Kristian Walker _Adaptavist_
November 28, 2024 edited
Hi Digvijay,
The code for Summary is correct as Summary takes a string as input but the Description field requires you to provide the description in Atlassian document format.
You can see details of what each field requires in the docs here.
Fior setting the description we have an example in our Script Libray here that you can use as an example to see how to do this.
I hope this information helps.
Kristian
FREE
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
