Set default watchers for a project
Arthur June 7, 2012
Is there a way to set default watchers for project issues? I know that creator of an issues automatically becomes a watcher of that issue. Is there a possibility to have every new issue in a project assigned default watchers (say, project manager, tech lead, etc.)?
Deleted user March 2, 2017
I solved this by creating a new Project Role called "Watcher", adding that to all events in our Notification Scheme, and then adding people to the "Watcher" role in specific projects as necessary.  This is more flexible than using the "Project Lead" field.
Brett Strydom
December 13, 2017
This "Sort of" solves the problem.  This thread was specifically opened for automatically being added as a watcher by default.  Your solution achieves something similar but the person is not added as a watcher.  The person is simply notified of everything without being an actual watcher on the issue in JIRA.
Jobin Kuruvilla [Adaptavist]
June 7, 2012
Since it is JIRA OnDemand, you can't add any plugins and hence overriding standard functionality is not an options.
But you should be able to achieve the same behavior by adding project lead etc in the notifications.
https://confluence.atlassian.com/display/JIRA/Creating+a+Notification+Scheme#CreatingaNotificationScheme-Addinganeventrecipienttoanotificationscheme
Nirosh Perera
October 16, 2020
Create default Watchers for Project which is effective automatically at the creation of each task of that project:
1. Fist have all the people added to your project by:
>> Project Settings >> People >> add users as required
2. Then add default users from the people you have added in the project:
>> Project Settings >> Automation >> Create rule (find: Right top corner) >> Select the trigger: Issue created (or you can any other trigger as required) >> Save >> click - Add component >> New Action >> Type: "Watcher" in All action search box >> select: Manage watchers - it comes after search >> Click : Add these watchers - select all the people you want to give this viewing privilege >> Save >> Click: Rule details >> Give a name to rule >> Save >> Click: Rule details >> Click: Publish rule at top right corner.
Register today
