I would like the priority of the parent issue to be equal to the highest priority of any of its sub-tasks. Does anyone know if there's a way to achieve this?
Thanks.
Not without a bit of code.
First you need to decide when you want to do this - check when a sub-task is created/updated? The parent? Both? Or some other time? Also, do you want to let the users overwrite it?
Then you'll need to write a listener or post-function to scan all the subtasks and adjust the parent if necessary. (I'd use the script runner to do that)
Learn more
