Set required custom field (Checkbox) when selecting option in dropdown field
Murugesan April 29, 2024
1. Custom field name  (Dropdown) --> SQL Script Execution
Values :
Yes
No
2. Custom field name (Check box) - New type of Script
Values:
Insert
Alter
Update
I want script for below scenario.
If I select Yes in SQL Script Execution custom field, then this field [New type of Script] will show as mandatory with mentioned values.
Thank you,
Murugesan.N
Jarosław Solecki [Deviniti]
We resolved that with  Dynamic Forms for Jira.  The whole configuration is really simple and you can set it under the specific project or globally for all projects that are using a specific scheme. Moreover, you also gain some additional abilities like show/hide fields, Set Default Value, Set Value based on condition, and read-only
Upcoming Jira Events
