1) I am currently using JIRA CLOUD.i have added several custom fields. and now there is a require for restricting editing on certain fields during editing issue screen.
2) I want to set mandatory for some custom fields fields in issue resolve screen
1. If you do not want a field to be edited, then do not put it to the Edit screen.
2. Use the Field Required validator.
Hi Alexey,
if the field is not in the Edit Screen I don't see it anymore.
I would need the field to be displayed also in the Edit Screen but readonly.
is it possible?
