Set the epic link of an issue created with ScriptRunner clone an issue and links
Geert Graat
December 19, 2017
I am trying to set the Epic link of an issue that is created with the clone an issue and link script from ScriptRunner.
I have the following script in a post-function in the additional actions field:
import com.onresolve.scriptrunner.runner.util.UserMessageUtil
issue.summary = '[SR] ' + sourceIssue.summary
def issueManager = ComponentAccessor.getIssueManager()
def epicIssue = issueManager.getIssueObject('AQ-12249') // Support requests epic
def epicLink = customFieldManager.getCustomFieldObjectByName('Epic Link')
issue.setCustomFieldValue(epicLink, epicIssue)
UserMessageUtil.success("Created issue for development.")
When I run this, I get the following Nullpointer:
Caused by: java.lang.NullPointerException
at com.atlassian.jira.issue.link.DefaultIssueLinkManager.getIssueLink(DefaultIssueLinkManager.java:373)
... 2 filtered
at java.lang.reflect.Method.invoke(Method.java:498)
at com.atlassian.plugin.util.ContextClassLoaderSettingInvocationHandler.invoke(ContextClassLoaderSettingInvocationHandler.java:26)
at com.sun.proxy.$Proxy211.createIssueLink(Unknown Source)
... 2 filtered
at com.atlassian.plugin.osgi.bridge.external.HostComponentFactoryBean$DynamicServiceInvocationHandler.invoke(HostComponentFactoryBean.java:136)
at com.atlassian.greenhopper.manager.issuelink.EpicLinkManagerImpl.createLink(EpicLinkManagerImpl.java:322)
at com.atlassian.greenhopper.manager.issuelink.EpicLinkManagerImpl.updateLinksForIssues(EpicLinkManagerImpl.java:238)
at com.atlassian.greenhopper.manager.issuelink.EpicLinkManagerImpl.associateIssuesWithEpic(EpicLinkManagerImpl.java:179)
at com.atlassian.greenhopper.service.issuelink.EpicServiceImpl.addIssuesToEpic(EpicServiceImpl.java:103)
at com.atlassian.greenhopper.customfield.epiclink.EpicLinkCFType.associateIssueWithEpic(EpicLinkCFType.java:686)
at com.atlassian.greenhopper.customfield.epiclink.EpicLinkCFType.createValue(EpicLinkCFType.java:202)
at com.atlassian.greenhopper.customfield.epiclink.EpicLinkCFType.createValue(EpicLinkCFType.java:44)
at com.atlassian.jira.issue.fields.ImmutableCustomField.createValue(ImmutableCustomField.java:693)
at com.atlassian.jira.workflow.function.issue.IssueCreateFunction.execute(IssueCreateFunction.java:81)
at com.opensymphony.workflow.AbstractWorkflow.executeFunction(AbstractWorkflow.java:1014)
at com.opensymphony.workflow.AbstractWorkflow.transitionWorkflow(AbstractWorkflow.java:1407)
at com.opensymphony.workflow.AbstractWorkflow.initialize(AbstractWorkflow.java:606)
at com.atlassian.jira.workflow.OSWorkflowManager.createIssue(OSWorkflowManager.java:741)
Any ideas what I am doing wrong here?
Geert
Thanos Batagiannis [Adaptavist]
December 19, 2017
Hi Geert,
You additional script looks fine. So I suppose the issue may is with the clone issue post function configuration. Do you mind to share that configuration ? For example which fields you selected to be copied, etc.
Also for which step you have set up the post function and in what order ?
Geert Graat
December 20, 2017 edited
Hello Thanos,
Thank you for your reply. Below are screenshots from the clone-and-link configuration and the workflow in which this function is called.
Please note that I disabled the additional issue actions which caused problems, so you do not see them here.
Geert
Geert Graat
December 20, 2017
Ok, something else I just noticed: we cannot set this specific epic link for any issue, and when I navigate to the (epic) issue, it shows an error as described here: https://confluence.atlassian.com/jirakb/issue-screen-displays-error-rendering-greenhopper-epics-issue-web-panel-779158857.html.
So I think the epic issue is somehow corrupted.
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
