Hi.
I'm trying to create a new jira story using a dictionary in python. Everything works except the setting of the Fix Version/s field. Here is the code:
def create_gen_jira_story(jira_project,summary,description,issuetype,assignee,labels,fixby,fixversion):
# Creates a general jira story with a pre-defined set of values. Uses a dictionary to build the story
issue_dict = {
'project': {'key': str(jira_project)},
'summary': summary,
'description': description,
'issuetype': {'name': issuetype},
'assignee': {'name': assignee},
'labels': [labels],
'customfield_10002': str(fixby),
'fixVersions': fixversion
new_issue = jira_con.create_issue(fields=issue_dict)
when I run the python script I get the following error:
response text = {"errorMessages":[],"errors":{"fixVersions":"data was not an array"}}
Question is - how can I set the "Fix Version/s" field?
If I remove the "fixVersions: fixversion" line the story is created correctly
The API documentation shows the "fixVersions" field expecting a list of dictionaries:
"fixVersions": [ { "id": "10001" } ],
You will almost certainly need to look up the project ID based on the version name to know the ID value(s) that you want to use.
You might try with an array of strings ? and add operation too ?
See the following example: https://community.atlassian.com/t5/Jira-questions/Error-data-was-not-an-array-when-updating-customfield-and/qaq-p/1321407
Nicolas
