Setting approvers based on multiple groups - scriptrunner
Kántor Tibor
December 15, 2021 edited
I'm trying to set up an approval process, where the users only have to select the specific systems they need access to and script runner automatically fills approvers based on this selection.
Now I figured the following solution:
  • Create a multi select list custom field
    • Fill this field with active directory group names
  • Create a listener for issue create and issue update events
  • Get the selected group names
  • Get the users from these groups and add it to a list
  • Set these list of names in the approver field
I had partial succes in creating this script, and also created a mess:
import com.atlassian.jira.project.Project
import com.atlassian.jira.project.ProjectManager
import com.atlassian.jira.security.roles.ProjectRole
import com.atlassian.jira.security.roles.ProjectRoleActors
import com.atlassian.jira.security.roles.ProjectRoleManager
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.user.util.UserManager
import com.atlassian.crowd.embedded.api.Group
def groupManager = ComponentAccessor.getGroupManager()
def userManager = ComponentAccessor.getUserManager()
def issue = event.issue
def componentManager = ComponentAccessor.issueManager
//CustomField userSelectedGroups = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Selected systems")
//def selectedGroups = issue.getCustomFieldValue(userSelectedGroups) as List
def selectedGroups = ["group1", "group2"]
if(selectedGroups == null)
return;
def users = "" as List
def i = 0;
while ( i < selectedGroups.size()) {
def members = groupManager.getUsersInGroup(selectedGroups[i])
def j = 0;
while ( j < members.size()) {
users.add(members[j])
j++
i++
CustomField approvers = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Approvers")
approvers.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(approvers), users), new DefaultIssueChangeHolder())
So this works, when I add a list of groups here in the script, but when I try to get the selected values from the multi picker field it does not work. I think the problem is getting the multi select list values as a list...
Any help would be appreciated!
Kántor Tibor
Eventually I found the solution:
import com.atlassian.jira.issue.IssueManager
def userSelectedGroups = customFieldManager.getCustomFieldObjectsByName("Permission to")
def selectedGroups = issue.getCustomFieldValue(userSelectedGroups[0])
def userList = []
selectedGroups.each {
def users = groupManager.getUsersInGroup("$it")
userList.addAll(users)
approvers.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(approvers), userList), new DefaultIssueChangeHolder())
