Is it possible to set the jira.node.id through a variable?
For example:
jira.node.id = ${HOSTNAME}Sadly, the above example doesn't work. My node id becomes the text "${HOSTNAME}"
Jeff,
Here is what someone else did to solve the issue. https://community.atlassian.com/t5/Jira-Core-questions/cluster-properties-file-get-jira-node-id-ID-automatically-like/qaq-p/753801
Ick. A solution, but not very elegant.
Have you solved this issue? If yes please share your experiences because I'm facing the same problem.
I much appreciate your support
Referencing the above link, @Lessandro has a script to modify the cluster.properties before Jira is run (e.g. at reboot or via cron)
HOST=$HOSTNAME
JIRANODE="jira.node.id = "$HOST
sed -i "2s/.*/$JIRANODE/" /var/atlassian/application-data/jira/cluster.properties
The cluster.properties file only needs to be modified once, so a process that happens over and over seems a bit much.
However, I have a recipe I follow that includes a step to modify the file whenever I am adding a new Jira node. There are times I have overlooked the step in the past, so there is merit to an automated process.
