We set up a board in ProjectA and changed the filter so that tickets from ProjectA and ProjectB appear in this board.
It works fine. The only problem is that this board appears in ProjectB too but we only want to have this board in ProjectA.
The filter query looks like this: "project = ProjectA or project = projectB"
Any idea on how to fix this so we can create a board that displays the tickets from two projects in one project without also appearing in the other one?
Regards.
Consider that boards are simply visual queries of data. So if you don’t want certain issues to appear in a board then the underlying filter query must exclude them. I can’t tell you precisely how to modify your queries without better understanding your situation. Maybe you could share the two board filters and convey what you don’t want shown. Note if you don’t want the second board at all then you can delete it altogether. Except if the board is a default board created for the project in which case you cannot do anything with those boards including changing the filter it is based upon.
