I'm trying to share a dashboard I created (I'm the admin) but when I edit the dashboard under Shares it shows 'Not shared' and I see no way to change it.
Hi Dennis,
This may be a permissions issue....Check the global permissions to see if you have access to "Manage Shared Objects," it may be restricted in the permissions scheme.
-Scott
Hi Scott,
I have site-admin, administrator and jira-administrator permissions. Those groups are listed in the global permissions for share dashboards and filters. I click on those groups listed and I see my user listed (group members = me). FYI, this is for Jira core (if that makes a difference) and I still can't share anything
Another question for you...
Are you the owner of the dashboard? Only the owner can edit and share it, but as an admin you can change the ownership; make yourself the new owner and then you should be able to share it.
If you are the owner already then I'm stuck...I'll ask some of the other Community Champs. I'm not aware of any limitations with Core, but I could be mistaken.
-Scott
FYI...
Before changing the ownership of a shared dashboard, ensure that you inform the shared dashboard's current owner of your intentions.
How do I verify I'm the owner? When I login it only shows me "my" dashboard (or so I thought I created it under my account).
I copied that dashboard to a new one and I can't share that one either.
