Show Jira Cloud issues in Jira Datacenter Dashboards
Akhand Pratap Singh October 21, 2022
Hi Team,
I have 2 Jira instances Jira Cloud and Jira Datacenter ,and have integrated both the Instances and are able to link issues across the instance .
I want to know how can we show up Jira Cloud issues in Jira Datacenter instances to have a common reporting for the dependent projects, if that is possible?
Thanks-you
Ivan Garcia _Appfire_
My Spider-sense told me that you suggested our app @Fabian Lim We really appreciate it! :)
Hi @Akhand Pratap Singh !
You indeed can report on both Cloud and Data Center effortlessly with Dashboard Hub for Jira. See the screenshot below or access this live dashboard to see it yourself (shared with Dashboard Hub's External Share feature).
Other features include JQL Custom charts, +70 gadgets, pre-built templates, and much more.
Hope it helps,
Iván, Product Marketing Manager
Fabian Lim
You may want to consider the dashboard hub plugin that allows you to report on multiple Jira instances.  This is one of the plugins that is growing fast in the marketplace: https://marketplace.atlassian.com/apps/1223898/dashboard-hub-for-jira-reports-charts?tab=overview&hosting=cloud
Good luck!
SERVER
VERSION
9.0.0
