I do have a custom field type (A) which I can't make readonly in a certain workflow step with ScriptRunner (It's probably not supported).
Let's say I do have the workflow steps Status 1, Status 2, Status 3
My workaround is to create a new JIRA custom field (B).
Problem with Behaviours is that I cant differentiate between Hiding and making a field Readonly for different statuses.
Is there a way with a script to solve the problem?
Joerg
In a behaviour you can check what workflow step or action you are currently on if you attach a server side script to the initialiser or one of the fields. Please see example #7 here.
You can modify the example to be something like:
if (getActionName() == "Start Progress" || getDestinationStepName() == "Done") { // <7> formField.setHidden(false) formField.setReadOnly(true) } else { formField.setHidden(true) }
This should achieve what you want.
