I would like to show a screen, without doing a transition. The screen is meant to add/update some custom fields.
The there any possibility for this?
Thanks, Marijn
You can create a screen during a transition, however transitioning it to the same Status.
Andre
Or use the "edit" option
You can also set a transition From: Any Status To: Itself This creates a global transition. However, I believe the Edit screen and Transition screens are our only options.
