ShowFlag in Post Function Forge App
TMonatisa March 17, 2025
Hi
import { showFlag } from '@forge/bridge';
export const postfunction = ({ issue, transition: { from, to }, configuration: {message} }) => {
console.log(`PostFunction for issue ${issue.key} for transition from status ${from.id} to ${to.id} with config message: ${message}`);
const flag = showFlag({
title: 'Hello World!',
type: 'info',
description: 'Here is a flag body description.',
actions: [
text: 'Flag action',
onClick: () => {
console.log('flag action clicked');
isAutoDismiss: true,
flag.close();
I am developing a Forge app that displays a message when an issue transitions to another status. While I can see the message in the console when using console.log, I am unable to display it using ShowFlag.
Since this is a Custom UI app, could you assist me in ensuring the message appears correctly? Any guidance would be greatly appreciated.
Kind regards
Tiisetso Monatisa
Tim Pettersen
March 17, 2025
Hi @TMonatisa
The `showFlag` function is only supported on the client-side, whereas post-functions are evaluated on the backend. You can't use it directly in a post-function module.
However, you can workaround this by using an `issueViewBackgroundScript` module to use the `showFlag` function instead.
I created a little example app that uses this technique last week for another customer: https://github.com/kannonboy/forge-toaster
It allows an admin to create a message targeting a specific user which is then displayed as a flag the next time they view an issue or a dashboard in Jira. At the moment it does this via an `adminPage`, but you could adapt it to create the message from a post-function instead.
cheers,
Tim
TMonatisa March 18, 2025
Hi Tim
Thank you. I will use the workaround.
ELFAPP Technologies
March 17, 2025
Hi @TMonatisa
That's the same example in the documentation minus being nested with an export function. Probably you should not include the showFlag object inside an export function.
Hi @ELFAPP Technologies
So where should I call the showFlag if not in the export function?
ELFAPP Technologies
March 17, 2025 edited
I think for you to use it the way you want, you most probably want to return showFlag then you can include it in the export function. For example
const flag = () => {
return showFlag({
type: 'info',
actions: [
onClick: () => {
${message}`);
flag().close();
atlassian, loom, AI, meeting recording, community
[NEW] Record your meetings with Loom
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
Learn more
