Showing linked hierachcy with two link types in a tree view
Jouni Riimala
May 4, 2022 edited
I have epic type issue called Requirements, which is linked to user need issues, which are again linked to child issues and so on..
Currently user needs are linked to Requirements epic via relates (Child) link type and user needs are linked to child issues via contains link type and so on.
I'm trying to develope a filter, which would show all issues from this epic in hierarchy (tree view) so would need help with jql or guidance for good plugin etc in order to come up with traceability type of report.
Managed to list all child issues via scriptrunner plugin, problem still is that how to show those in tree view instead of list view ... ?
3 votes
Fabio Racobaldo _Catworkx_
Hi @Jouni Riimala ,
welcome to the Atlassian community!
Unfortunately this feature is not available on the cloud using builtin capabilities.
There are some available apps on the marketplace :
Hope this helps,
Fabio
Erik Unemyr_EMERGENCE July 20, 2022 edited
Dear @Jouni Riimala
You may want to try out the newly released Move and Organize for Jira app that provides a dynamic view of your Jira projects in a tree hierarchy.
It allows you to visually overview and also edit on-the-fly (create, edit, recursively move, delete et c) issues. Zoom and pan the tree view quickly and smoothly using keyboard shortcuts and mouse drag-n-drop support that enable you to work very efficiently also with larger projects!
Finally, it does not require any customization of your existing Jira projects - it plugs in directly for your users without making any non-standard customizations to the project or its issues.
Feel free to reach out to me directly if you have any questions or would like to provide suggestions!
With best regards,
Erik
Disclosure: I am a representative of the company offering this solution
Rahul_RVS
Hi @Jouni Riimala
Welcome to the community !!
To visualize the tree hierarchy based on the issue links, we have created an add-on to track the progress at each level. Please try it out !!
Issue Hierarchy Reports
Key features:
  • Hierarchy upto 10 levels deep
  • Progress % on "remaining estimate" or "original estimates"
  • Edit Issue summary, time estimates, story points and assignee on the tree with real time updates in the progress
  • Rolled up percentage completion at all levels
  • Ability to add/remove the columns on the report
Disclaimer: I work for RVS, the vendor for this app, and I am one of the developers in the team
Jouni Riimala
I tried and it's quite ok. Few hopes to export section though.
#1
It would be nice, if one could define headers as now those are named as Level_<int>_Key. For example those could be named in general as First level, Second level etc.
#2
Summary field would be good with the key and truncated to certain length. By default Issue type would be good as a first column. Justification is that without using issue type field it's impossible to know what type of issue you are looking at. Additionally if it would be first column by default that would make type instantly clear.
#3 Fields:
Assuming, if I create a new custom field I can also use that field in views and later on with exports ?
Rahul_RVS
Hi @Jouni Riimala
Thanks for trying out the app.
Regarding #1 & #2, we will certainly implement this. I will keep you updated as soon as it is published.
Regarding #3, yes you can include custom fields in your reports and it will be exported as well. Also the report will roll up number custom fields and you can edit them too on the report screen.
Please do let me know for any other queries.
Jouni Riimala
Maybe one more observation, reproduce this.
1. Create an epic.
2. Add about five child items.
3. Link one of those child item so that child created in section 2 is parent of this child.
4. Run hierarchy report and you might see that linked child item is appearing under epic and also rightfully under one child parent. Shortly you can see same id in two places which is not good.
... I confused even me, but hope that you got my point.
Rahul_RVS
Hi @Jouni Riimala
We are not able to reproduce this issue at our end.
Can you pls share your email details on support@rvsoftwares.in
We can jump on a zoom call to look at the issue.
Jouni Riimala
Not a priority now ,let's do it later if required. Looking forward next version from your plugin.
Rahul_RVS
Thanks @Jouni Riimala
I just re-looked at your scenario, and it seems like this how the data is set up and the hierarchy shows it that way.
Please reach out to us for further clarification.
Jouni Riimala
Any timetable for those #1 and #2 fixes ? Thinking that it requires also re-installation so looking forward info when to do this.
Rahul_RVS
Hi @Jouni Riimala
Thanks for your reply.
Can I request you to please reach us at support@rvsoftwares.in
