Showing time difference on current (now) time
Ray Balmeo Cagayon April 10, 2024 edited
I created a rule to measure the current date time against a target completion date but it seems that my results are being roundup somehow.
{{"Need By Date".diff(now).hours.abs}}
It seems to be working if the "Need By Date" value is too far away that i don't care the differences in hours but if the current time is now and my "Need By Date" is tomorrow, I am always getting a 24 answer which is a day away instead of 8 or 9 hours if its already in the afternoon.
I tried playing around with the now extensions but although the rule successfully I am not getting any results.
I am suspecting that since my "Need By Date" is a date field not a datetime field, Jira is purposely ignoring the time data.
I dont want to change the configuration of my "Need By Date" field so is there a way to trick it to format it to be a datetime.
Sebastian KrzewiƄski
Hi @Ray Balmeo Cagayon
What type is Need By Date field? Is it date picker or date/time picker?
Seba
@Sebastian KrzewiƄski
it’s a date picker.
You are making diif between field that store only date with now which is date/time. For automation diff will be based only on dates so diff will be always 24/48/72/96/etc.
Seba
Like ‱ Bill Sheboy likes this
That's what i suspected as well. I'm getting the admins to change the field type.
