Single component can use for multiple projects ?
ariharan m
Hi team, for that i have one feature name as component, I want to track all the user story comes under that one feature. so i want to use this single component for multiple projects . how to do that? Is there any possibility there ?
Mirek
December 30, 2024
Hi @ariharan m
Components are created per project. If you want something more generic use Labels or simply Custom Fields. Of course there is nothing wrong with using Components in the same name in different projects then when you define JQL it should work when using its name. Just the problem is that you have to create/update them when there is a change.
