Single user field setting to empty, automation
Arturs Kalnins
I have a checkbox called "approved"  and a single user field called "approved by"
I am amble to write an automation that If a user clicks Approved, the triggeruser ({{initiator}}) is set to approved by field.
However I cannot find a way, once "approved" has been unchecked, the field "approved by" to be cleared out. I've tried {{clear}}, {{remove}}, {{none}} but nothing seems to work.
Thank you in advance.
January 30, 2024
Hi @Arturs Kalnins
For a question like this, please post an image of your complete automation rule, images of any relevant actions / conditions / branches, an image of the audit log details showing the rule execution, and explain what is not working as expected.  Those will provide context for the community to offer ideas.  Thanks!
Until we see those...
In the rule's edit issue action, have you tried selecting the custom field from the dropdown list and just leaving it empty?  That normally works to clear a field.
Arturs Kalnins
January 30, 2024 edited
The "{{None}}" does not work, I need it to empty Single pick user field in this place
January 30, 2024
Please try just leaving the field empty, with no selections or smart values.
Arturs Kalnins
that does not work, i've already tried.  I believe this works on Assignee field but not with a single pick user field
January 31, 2024
I just tried that with a company-managed project, using a single user-picker custom field and it worked.
What type of project are you using: company-managed or team-managed?
Arturs Kalnins
company managed project.
I'll check again. Ill look into audit log, perhaps i'm missing something.
