I am trying to create Unique ID as the default key generated by Jira is not sufficient for my project.
If my Unique ID is based on two fields:
1) issue.key (the one generated by Jira)
2) Request Type (custom field created by me which has 6 to 7 dropdown values each value is a combination of TEXT and a Code). for example "Deployment Focus Training-DFT" here "Deployment Focus Training" is the text and "DFT" is the code.
so is Issue.key is MEA-15 and Request Type is "Deployment Focus Training-DFT"
My Unique ID should be "DFT-15"
for this I have written the following code in the Automation, but its now working:
{{issue.Request Type.split("-").last.concat(issue.key.split("-").last)}}
Kindly guide what am I doing wrong.
I have tried the below code as well, this also didn't work.
{{issue."Request Type".split("-").last.concat(issue.key.split("-").last)}}
Hi @Jithesh ,
have you tried without the concat function ? If you juste add both values like this it should work :
{{issue.Request Type.requestType.name.split("-").last}}-{{issue.key.split("-").last}}
Let me know if this helps,
--Alexis
The first part is not working: {{issue.Request Type.requestType.name.split("-").last}}
I also tried: {{issue.Request Type.name.split("-").last}}
Request Type is a single choice Custom field I have created. Just FYI
I just saw that there is a system field with same name "Request Type"
so tried with changing the name of custom field and used the below code and it seems to be working.
{{issue.Training Request Type.value.split("-").last}}-{{issue.key.split("-").last}}
Thanks for guiding me to figure out this solution...
Ah great, I was wondering if you had actually created a new field with the same name or not.
Glad to know it's fixed, don't hesitate to mark this answer as accepted so that other users can find it later.
Have a nice day !
--Alexis
