Smartvalue for transition name
Jakob KN
May 22, 2020
Hi Community,
I'm setting up a Slack notification using Automation for Jira which triggers on transitions, I would like to include the name of the trigger transition, but can't seem to find a smartvalue for this in Codebarrels documentation.
Is there a smartvalue available for transition names?
Jakob KN
June 30, 2020
After being in contact with Atlassian support regarding this, it turns out that including Transition names as smart values is not an option, as mentioned in their reply:
"I just wanted to let you know that the Automation Development team came back to us, and unfortunately they confirmed that there is no way to fetch the name of the transition."
June 30, 2020
Thanks, @Jakob KN for the follow-up.  If you believe this would be a valuable capability, please consider adding it as a suggestion for Atlassian to consider.  Thanks!
Like # people like this
Margaret Boisvert
You can now user {{transition.transition_name}} in Jira Cloud Automation
Darryl Lee
Hi I realize this is necroposting, but... I'm not finding this to exist.
I tried Logging {{transition.transition_name}} as well as {{transition}} and both come up blank.
@Margaret Boisvert you have a rule that uses this?
Margaret Boisvert
I was mistaken on this.  It does not work :(
Margaret Boisvert
{{transition.transition_name}} can be used in a Jira expression Nunjucks script.  When I saw it there, I thought it would work in Automation as well but it does not
Luis Plaza Vidaurre
November 8, 2021
You may try to use changelog smartvalue that gives you as result when you transition from TO DO to IN ANALYSYS something like this:
Luis Plaza Vidaurre
November 8, 2021
it will not give you the transition but with some string processing you can evaluate the target status
Martin Cleaver
September 10, 2021
Is there a Jira issue tracking this?
@Gareth Cantrellmaybe you know? Or of a workaround using Scriptrunner?
Martin Cleaver
September 10, 2021
At the moment on DC, I just make custom events, and emit those on postfunctions.
The downside is one new event for every type of thing I want to bridge from a workflow to a rule.
A more general solution would be to capture a generic event (maybe Generic Event or maybe a new general "A4J Transition Event"), extract in ScriptRunner using listener, expose into a new SmartValue using scriptrunner, filter on transition name.
June 25, 2020
Hi @Jakob KN
I did not find the name of the transition in any of the smart value documentation from Atlassian.  You could try to find a representative issue which was transitioned, and then use the REST API to find if such a smart value exists.  Here is the how-to guide for that technique:
https://support.atlassian.com/jira-software-cloud/docs/find-the-smart-value-for-a-field/
If you learn the smart value, please post the answer in this thread.  Thanks!
Best regards,
Jakob KN
June 30, 2020
Hi Bill, it turns out that this isn't possible, unfortunately.
