This question is in reference to Atlassian Documentation: Using the Issue Collector
I've created a custom Issue Type, with some custom Fields. All the fields I need are showing up in that Issue Type's Create screen, no worries.
But when I try to make an Issue Collector for that Issue Type, some of the custom fields are missing from the options below the Template Preview. What do i need to do to fix this?
You need to add the fields using JQUERY yourself.
Some help can be found here – https://confluence.atlassian.com/jira064/advanced-use-of-the-jira-issue-collector-720411908.html If you can ask a more specific question or have a specific field you can use as an example, I might be able to help further.
That page shows how to set up a custom trigger, set default values for fields, and specify values of fields that don't appear in the feedback form, but I don't want to do any of those.
I want to make a custom field, which appears on the Create Screen of the Issue Type, also appear on the Issue Collector's feedback screen.
The field in question is a custom Label field.
It appears in the Issue Create screen in JIRA.
It doesn't appear on the Issue Collector screen.
Make the most of your time in Barcelona with our curated guide – discover how Jira, Confluence, Loom, and Rovo work better together, connect with Atlassian experts, and enter to win an Apple prize bundle!
Get the guide
