Sort statuses inside column
Sergio March 14, 2013
Hi All,
Is this possible to sort statuses inside column on the Task Board Mapping?
For example, I have statuses in the following order:
  • Development
  • Open
  • Done
  • Design
But I had want to see it as follows (for example):
  • Open
  • Design
  • Development
  • Done
Is that possible?
Many thanks!
P.S. Grenhopper v5.6.5 with JIRA 4.3
Timothy
March 14, 2013
As far as the plugin goes, there is no way to sort it now.
Sergio March 25, 2013
Thanks, I guess you're right.
Thanks all for your help
Renjith Pillai
March 16, 2013
Upgrade GreenHopper, Use Rapidboard and Use Swimlanes
https://confluence.atlassian.com/display/GH/Swimlane
Nicholas Muldoon
March 15, 2013
Hi Serge,
Are you trying to map one status to each column?
Open Design Development Done
If so, you will want to make sure that the JIRA Workflow you are using for the project supports dragging in the direction you expect.
Alternatively, you can upgrade to the latest versions of GreenHopper and JIRA and take advantage of the GreenHopper Simplified Workflow which will allow you to move columns as you please.
Thanks Serge,
Nicholas Muldoon
Register today
