×Hi community,
I recently set up integration with split. Now I can see the feature flag on my issue details under release field. But I'm wondering if it's possible to create a rule using Jira Automation to change status of the feature flag in split? I can only see the action as 'create feature flag in launchdarkly'.
I'm new to split. Does anyone know if it's possible? If so, how to configure the rule? Thanks.
As far as I know, LaunchDarkly is the only "feature flag platform" supported by Jira Cloud Automations.
If automation is important for you and you are still "new to split", you may want research on LD and eventually change to that...
