Sprint Completed email with Issue status
Jackie Brunetto
September 4, 2024
I am trying to create a very simple email that includes all the issues that were in a sprint and the status when the sprint closes.  Here is that I have set-up for the automation:
When: Sprint completed
Then Lookup issues:  sprint IN ("{{sprint.name}}")
And Send email:
{{sprint.name}} completed. Here is the status of all the issues in the sprint:
{{#lookupIssues}} * {{key}} - {{summary}} - {{Issue.status.name}} {{/}}
Everything seems to work fine except the issue status will not populate in the email.
Mikael Sandberg
September 4, 2024
Hi @Jackie Brunetto,
Try removing issue from the smart value and only use {{status.name}}, that should give you the status as expected.
Jackie Brunetto
September 4, 2024
Hi Mikael,
That works. Thanks so much for your help!
Like Mikael Sandberg likes this
