Sprint Date Custom field
Davor Fisher
Is it possible to create custom field called "Sprint Date Add" that will update automatically a date field based on the change in value of a sprint field.
Example: Issue created on 05/20/2016. Added to a sprint on 6/2/2016.
Sprint date add would then give a date value 06/02/2016.
This would be run for reporting purposes by a team that wants to know when an issue was exactly added to a sprint rather then checking the history tab of each issue. They want to be able to run a JQL and could use the Sprint Date Add to run a query based on that. It would visually also be good for reporting.
Kristian Walker (Adaptavist)
Hi Davor,
I have attached an example of how you can create a Scripted Field called Sprint Dates which will show for an issue what the Start and End dates for the sprint are.
I have attached below the code and config for the Scripted Field along with a screenshot of what the output on an issue looks like.
Code:
// Required Imports
import java.text.SimpleDateFormat;
import java.util.Date.*;
// Get the current issue key
Issue issue = issue
// Get a pointer to the CustomFieldManager
// Get a pointer to the sprint CF
def sprintCf = customFieldManager.getCustomFieldObjectByName("Sprint")
// Stop the values on screen showing old cached values
enableCache = {-> false}
// Define a new Java Simple Date Format
SimpleDateFormat sdfDate = new SimpleDateFormat("dd/MMM/YYYY");
// Get the Start and End dates for the sprint
Date startDate = issue.getCustomFieldValue(sprintCf)?.startDate?.first()?.toDate()
Date endDate = issue.getCustomFieldValue(sprintCf)?.endDate?.first()?.toDate()
// Format the dates with the Java Simple Date format defined
def formattedstartDate = sdfDate.format(startDate)
def formattedendDate = sdfDate.format(endDate)
// Construct the output String to be returned
String dates = "The Sprint Start Date is: " + formattedstartDate + "<br/>" + "The Sprint End Date is: " + formattedendDate
// Return the output String
return dates
Config:
image2016-6-7 11:13:3.png
Output:
image2016-6-7 11:13:27.png
I hope this helps.
Kristian
Davor Fisher
Hi Kristian,
I am actually looking for a field that will show the date when the issue was added to the sprint. This would help on reporting on issues which are added after the sprint has started.
stuart_urquhart_l3t_com
August 11, 2016
When I try this with live issues that have been in more than one Sprint, I get the wrong dates.
e.g. for an issue now in Sprint 3, using
“endDate = issue.getCustomFieldValue(sprintCf)?.endDate?.first()?.toDate()”
gives me the end date of Sprint 1
Changing it to:
“endDate = issue.getCustomFieldValue(sprintCf)?.endDate?.last()?.toDate()”
gives me the end date Sprint 2
Any idea what syntax I need to get the end date of the current sprint (Sprint 3)?
