Sprint field not visible in new issue view
Deleted user December 7, 2018
Field scheme clearly shows it should be showing, in spite of the fact that it shows when oldissueview=true.
For some reason JIRA is also now forcing the new view unless I manually revert (in spite of me using a Chrome add-on to force old issue view).
Is there a reason the new issue view is ignoring my field schemes?
6 votes
Matas Stumbrys
April 17, 2025
I have the same problem - sprint is visible in field configuration option - but in actual task view its gone.
Gayane
April 18, 2025
Same for me. Have you found any solution for that?
Stanislav Patskevich
April 18, 2025
the same issue after switching to the new UI
Mina Gharenazi
April 18, 2025 edited
for me too
Bianca Ghita
April 18, 2025
Same. Sprint is visible if the work item is open in the sidebar or preview(not full screen), but not when in full screen.
Nick
Same issue.
April 18, 2025
yes, you are right - sprint field invisible in a full screen, however, preview or sidebar work fine. I checked sprint field settings and everything should work. It seems that it's somehow connected with a new UI.
Televic Support
April 18, 2025
Same issue here unfortunately, in preview we can still check it but in full screen it's gone.
Like • Mina Gharenazi likes this
Arthur Bosma
April 18, 2025
Hi, I am having the same issue as well. Started today.
I notice a possible cause. I have a Scrum board which covers multiple projects. When I open the issue from the Scrum board (in my overarching scrum project), I can NOT see the Sprint field anymore.
But when I go to its own project and then open the issue, I can actually see the Sprint field again. This could be the cause of the bug perhaps?
Mateusz Czuba April 18, 2025
Same problem in our organization.
Przemysław Wójcik
April 18, 2025
Same here
Board view - sprint is visible in the issue details
Filter view - sprint is visible in the issue details
Single issue view - sprint is NOT visible in the issue details
Andrea Lincetto
April 18, 2025
Hi, Atlassian is aware of the issue and working on that
See https://jira-software.status.atlassian.com/
You can also subscribe to the specific issue to receive a notification as soon as it is has been solved
Like • 9 people like this
Andrea Santi April 18, 2025
I spent 1 hour of my life trying to understand what was happening, if someone from my team changed something...
I was feeling so stupid... and finally found the problem.
Can I have 1 hour of my life back please?
Like • Bianca Ghita likes this
Dave Markowski April 18, 2025
Same issue here.  This needs to be fixed up.  100s of projects impacted by this.
Like • Serdar Gökalp likes this
Serdar Gökalp
April 22, 2025
Same problem, please help us urgently. We can not continue to process...
3 votes
Alex Zavodchikov
April 18, 2025
Hey!
I don't see the a field in both full screen and sidebar layouts.
As the Atlassian confirmed the problem I could suggest a temporary solution:
1. Chose the task (make it active) - open it in full screen of choose from backlog/issues screen
2. Press "." (dot) on the keyboard, it'll open the action menu
3. Type "add sprint" or find it in the action menu
4. Edit sprint
jose.hernandez
April 22, 2024
You must have tje "Schedule issues" permission on the project ()
Project -> Project configuratión -> Permissions Search "Schedule issues"
Tomas Vrabcek April 19, 2022
Hi, when this will be fixed/implemented?
Petter Gonçalves
December 10, 2018
Hello Toby,
Thank you for raising this question.
In my Cloud site, the field Sprint is properly displaying in the new issue view as you can see in the screenshot below:
That being said, I would recommend you to perform the following steps so we can better troubleshoot the problem:
- Please, check if you have a custom field called Sprint or Sprints. Sometimes, a custom field with the same name can cause some confusion in the screen schemes
- You said the field is properly appearing in the old view. Can you please check if there are any values added to that field or if it's empty? If it's empty, try to select any sprints and check if the field appears in the new issue view.
- Can you please provide us the version of your Cloud site?
Sheri
Hi @Petter Gonçalves
I am having the same problem. We are on Jira Cloud. Sprint does not appear in the New Issue View if it is blank. If I switch to the old view I am able to see the field and assign the issue to the sprint. After that the field is visible. I do NOT have a custom field called 'Sprint' or 'Sprints.
Petter Gonçalves
July 1, 2019
Hello @Sheri
Can you confirm if the project you are using is classic or Next-gen? I see that you mentioned that in the old view it is not happening, so I just wanted to ensure you have tested it in the same project and not in a different one.
Also, check if the field is properly added under project settings > Issue Layout as not hidden.
Let us know if the steps above helps.
Sheri
HI @Petter Gonçalves
I can confirm that the project is classic and that the filed is not hidden. If the field is blank it does not show up in the New Issue view. Once a value has been populated it does show up.
Sheri
