×In Jira database, where do i find Sprint Started By and Sprint Ended By details?
In my instance for all agile reports like sprint report, BurdDown Chart, Velocity chart, i dont see values from Started By and Ended By
SELECT from_unixtime(ae.TIME / 1000, '%Y-%m-%d'), cu.display_name, ae.ID, ae.`DATA`
FROM ao_60db71_auditentry ae
INNER JOIN app_user u ON u.user_key = ae.`USER`
INNER JOIN cwd_user cu ON cu.user_name = u.lower_user_name
WHERE ae.CATEGORY = 'SprintOpenClose'
AND ae.entity_class = 'SPRINT' AND ae.entity_id = 311
ORDER BY ae.TIME ASC;
NOTE: 311 refers to the sprint id.
This is present in the AO_60DB71_SPRINT table in the database. You have a column there for start date and completed date. The times are in epoch time, so you would need to convert this using a tool like https://www.epochconvert.com/. Of course you would not be able to tell which board the sprints are coming from, therefore you will need to join this with the AO_60DB71_RAPIDVIEW table.
I am not looking for Start Date and End Date, i am looking for Started by and Ended By.
Please check attached screenshot.
