[Static type checking] variable [requestContentType] is undeclared
Tamil June 23, 2020
I am trying to write a script in Jira Workflow postfunction which sends POST to external server.
Below is my script to send POST request to url(http://test:8000). The below script gives error as
[static type checking] the variable [requestContentType] is undeclared
[static type checking] the variable [response] is undeclared
[static type checking] the variable [resp.status] is undeclared
I am new to groovy script. Could you please help me in understanding why the error occurs and correct way to send POST request to URL?
import groovyx.net.http.HTTPBuilder
import static groovyx.net.http.ContentType.*
import groovyx.net.http.ContentType
import static groovyx.net.http.Method.*
import groovy.json.JsonSlurper
import net.sf.json.groovy.JsonSlurper
def http = new HTTPBuilder('http://test:8000/process')
http.request(GET) {
requestContentType = ContentType.JSON
//body = [region: 'USERNAME', password: 'PASSWORD']
response.success = { resp, JSON ->
return JSON
response.failure = { resp ->
return "Request failed with status ${resp.status}"
Tamil
Slava Dobromyslov
April 6, 2023 edited
Yes, it's the nature of Groovy.
It seems to me you show us only a part of the code. This error occurs when you mark a class as compiled static. You can't do this with @CompileStatic annotation because HTTPBuilder uses a dynamic delegate for configuration.
Remove the @CompileStatic annotation, and everything will work. Here is my example:
import groovyx.net.http.HttpResponseDecorator
import groovyx.net.http.Method
// Do not mark it as @CompileStatic
class SomeService {
static void sendNotification() {
final http = new HTTPBuilder('https://example.com/notify')
http.request(Method.POST, ContentType.JSON) {
headers.put('authorization', 'Bearer MY_TOKEN')
body = [
text: text,
response.success = { HttpResponseDecorator resp, Object json ->
assert resp.status == 200
return json
response.failure = { HttpResponseDecorator resp ->
throw new RuntimeException(
"Can't send notification: " +
"${resp.getStatus()} ${resp.getStatusLine().getReasonPhrase()}"
Also, see more info in the RequestConfigDelegate
