Status colours without browser plugins
Andrew Newnham
August 4, 2025
We're planning a migration from YouTrack to Jira. One of the things we're trying to do is set up a set of status's inside Jira which match our business workflow, something that was trivial inside YouTrack.
Easy enough to set up status names, but I can't actually change colors of the status's, outside the Gray / Blue / Green "Category" options.
I don't want to instruct my team to download a browser extension to do this, so is there any plan on allowing people to set up meaningful colors for their status's, so I can tell at a glance how far through the process a task is,  with Red = Not Started through to Green = Completed.
I can only find posts about this from 18 months ago, and the AI chat's keep stating it can't be done without browser plugins, but there also seems to be some demand for it. So wondering if it's on the road map.
5 votes
Trudy Claspill
Hello @Andrew Newnham
There is a change request about it to which you can add your vote.
https://jira.atlassian.com/browse/JRACLOUD-63999
There is a link in each change request to Atlassian's new feature policy which you can review for information on how they evaluate and prioritize change requests.
Andrew Newnham
August 4, 2025
Done, thanks for that, although doesn't give me confidence that the suggestion has been around since 2017.
Matt Doar (Adaptavist)
One of the problems with using colors in statuses is that some of your users won't be able to tell them apart (color blindness). Jira doesn't allow patterns for statuses either, which would help with that. My approach is to make sure that the status names are clearly distinguishable in their first word, which helps somewhat
FREE
