Status is In Progress but Resolution is Done?
Tan Phan October 25, 2019
Anyone can help me to fix this case. The status of ticket is In Progress but Resolution is Done, also I have date to done as image as below. How can I remove the Resolve date in this case and remove Resolution (Done).
Torben Bundt October 25, 2019
Make sure that the global transitions to the To Do and the In Progress statuses have an Update Issue Field post function that sets the resolution field to None
This is how it should look like (in this case for a non global transition):
tran.png Changed, but the issue is still happen the same. :(
Updated. Change the status in ticket to In Progress it will be applied imediately. Fixed.
Haran Kumar
October 25, 2019
Hi @Tan Phan
  1. Check the post function properties in the transition to In progress status from the workflow.
  2. In todo status make the resolution to set to Unresolved.
  3. Now set resolution done only  the done transition.
  4. Selecting todo will make all tickets resolution back to unresolved
  5. And only when the ticket is done the resolution will change to done.
  6. Hence your In progress tickets will not have done resolution.
Hope this helped you
Regards
Haran
Hi @Haran Kumar , just do it but don't have Unresolved option to choose. How can I do?resolution.png
Thanks, Fixed
Like • Ravi Sagar _Sparxsys_ likes this
Haran Kumar
October 25, 2019
Best wishes
October 25, 2019
Hi @Tan Phan
May be there is a post function that is setting the resolution on In Progress transition. You can click on the In Progress transition, the arrow and check the post functions.
Ravi
Here is my workflow. I'm just investigating to family with it. So in my workflow that is right or wrong? what I need to change?
Fixed
