Story Point Estimation Summary
Hakeem May 28, 2019
I need help please.
I have set story points for a number of tasks under different stories. I expect to see the summary at the top of my sprint board but this is not happening.
Thanks.
Jack Brickey
@Hakeem , where do you expect to see the SPs and why do you expect to see them there? Can you provide an screenshot?
Hakeem May 28, 2019
Thank you Jack. Please see screen shot below.
In response to why the team want to see the story points there - There is no visibility as to the total amount of work. in efforts was selected for development in a sprint.
Jack Brickey
Ok so yes that is what you should see in the backlog view and it appears you are. So are you asking to see the same thing in the Sprint board? If so consider using a dashboard and maybe the sprint gadget or similar.
Hakeem May 28, 2019
So, the screen shot is for an existing project that is fine. I have another project that does not have that type of view. See screen shot.
Hakeem May 28, 2019
Hi Jack, I figured it out already.
Step 1 - I went back to the old Jira view via my personal settings and turned off the "New Issue view" (I missed this view though).
Step 2 - I went to the custom field and replaced the "Story point estimate" with "story point". I went back to my project backlog and re assigned the story point properly and it worked.
I really want to appreciate your time.
Register now
