Is it possible to set story points as the default instead of original time estimate, within stories/tasks and sub-tasks, as part of global settings so that you do not need to do it each time you create a new project board?
You need to change the context of story point field in Jira admin settings.
Choose all the issue types in context
https://support.atlassian.com/jira-cloud-administration/docs/edit-a-custom-field-context/
Pramodh
