Story Point estimate is getting displayed as story point estimates in view/Edit screen. If I add Story Point estimate to my issue layout page then it is displaying story point estimate filed two times in the page.
In Create issue and old detail issue fields are displaying correctly. this problem is only in new issue page.
Thanks in advance.
Hi @Vijaya
I think the jira admin created 2 'story point estimate' fields in JIRA. Check with them to rename one from the custom fields screens to understand which one is actually used by your team and remove the unnecessary one.
Save your spot
