Story vs Task contradiction
Pietros
I have been quite confused as in JIRA glossary, it says that a task is a unit of work within a story. In the community discussion, people say that a story is the same level as a task.
So in JIRA Agile, should I use Stories or Tasks as parents for sub-task? Is there a difference if I use the Epic-Story-Subtask or Epic-Task-Subtask?
Nic Brough -Adaptavist-
May 12, 2017
JIRA refers to things as simple "issues", although there are usually many types, and users can, and do, define their own types.
The heirarchy is simple:
  • Epic
  • Issue
  • Sub-task
But, for issues and sub-tasks, you can define your own types.  Most of us are used to having something like:
  • Issues:  Issue, task, story, bug
  • Sub-tasks: sub-task, technical task
A common variation:
  • Issues: Issue, story, bug
  • Sub-tasks: task, technical task
The point here is that you can call your issues anything you want.
Deleted user June 26, 2019
The issue hierarchy in the version of JIRA that i used was as follows:
Epic > Stoy > Task > Sub-Task
I'll use an example of how i interpretted this:
  • Epic
    • Login functionality
  • Story -
    • API integration
    • FE design
    • FE development
  • Task -
    • Include captcha
The thumbrule i follow is as follows:
  • Epic -
    • A broad bunch of features/functionalities that stands on its own
    • Ex - Login functionality
  • Story -
    • Bunch of slightly less broader features that also stand on its own but rollw up to the Epic
    • Ex - API calls to the secure database like say a Ping federated login service
  • Task -
    • Unique units of work that maynot explicitely fall under or not broad enough to come under a story
    • Ex - Adding a captcha functionality
Hope this helps.
Stay curious yo!!
Cheers!
