×Hello,
I am trying to show the variance between the sum of Original Estimates compared to the sum of Time Spent rolled up to the Epic.
Hi @Keiko Kamiya ,
Haven't come across as example using the variable in the if else statement. Usually, it a custom field.
See this similar post:
IF you do not get an answer here, I would suggest reaching out to structure vendor to see if it possible and how. They will likely have a direct answer. Here's how to submit a ticket:
