Structure Grid + Details layout is not loading
Barys Harbacheuski July 12, 2022
What should be done in order to solve the problem of infinite loading of structure layout Grid + Details? Everything seems to be ok, no errors anywhere.
All structures are affected, clearing browser cache doesn't help. We've just updated Jira to 8.20.9, Structure plugin is 8.0.1
David Niro
Hello @Barys Harbacheuski ,
David from ALM Works here.  For this, it will be best to reach out to our support team directly via email support@almworks.com or through our customer portal support.almworks.com.
We will be able to help you identify the cause of the issue.  Some things that we may request, and you can collect in advance:
Performance Audit Log : Administration | Structure | Support | View Performance Audit Log.
Support ZIP
HAR Network Report
Best,
David
Barys Harbacheuski July 21, 2022
Hi @David Niro , thanks for responding, we found the cause of the issue and it is not Structure, other plugin causes it.
Like • 2 people like this
David Niro
Glad to hear you were able to find the culprit, @Barys Harbacheuski !
Thank you for following up to let me know!!
Help us plant more trees
